iBangKaty
- January 6, 2008
- Little Neck, New York
- 98 XLT V6 SOHC
im gonna get a 98-01 sport
is this what parts i need / what i need to do to make this work?
1. Engine bay wiring has to be switched to v8 wiring.
2. Brake booster must be changed out with the V8 one.
3. Engine mounts must be changed to v8 mounts.
4. Drop the front axle a couple of inches to swap in the engine mounts.
5. swap out the v6 cooler for the v8 power steering cooler.
6. switch out throttle and trans cables
7. Swap the front flange from a V8 driveshaft onto the V6 shaft. This is done by pressing out the u-joint.
(is it better to shorten a 4door v8 shaft? someone on here said Quote: "The front driveshafts are different lengths according to my driveline shop. Make sure those stay with the drivetrain they came from. They may fit, but the lengths are optimized. I think the V6 front shaft is about an inch longer than the V8's.")
8. 5.0 engine (drop in)
9. 4R70W transmission
QUESTIONS.........
1. is that everything? or do i need more parts or anything else?
2. I dont want an automatic trans....
i would like a 5 (or 6 if its possible) speed manual.
which 5 speeds will bolt in to the 5.0 sport? / what do i gotta do to make
that happen?
3. I want the sport to be 2wd.
Is it easier to have a 2wd sport to start with? does it matter which donor
v8 x i get as long as its between 98-01?
4. Is it easier to have a manual trans sport to start with?
QUESTIONS.........
that happen?
