FordJimbo
- May 7, 2020
- NYB
- 1998 Explorer
I've got a 98 Ford Explorer with the 4.0L SOHC V6. My Vin has an "E" as the 8th letter.
A job that should be easy and quick took over 2 hours last night. It's my fault I did not label the plug wires (which should be color coded or numbered or something anyway). User error. I probably should have done them individually, but I had removed the boots to spray some liquid wrench on the plugs to aid in removal so I wouldn't break one. And I didn't reinstall the boots so as to not cause a problem continually tugging on them... I should have put tape or something on them. I thought I laid them out and could identify which goes where.
But in my contorting to get to the drivers side plugs, I must have moved the wires. I put them back on and before tackling the passenger side, which was going to be today, I started the vehicle and heard a loud "bang" and a very rough idle. I shut it off. Today, I thought I found a wiring diagram that shows which goes where. I had mixed 4 and 6 up, so swapped them. The vehicle ran rough. I drove it around the block and it stalled out twice. A distinct unburned fuel smell.
I've not yet done the passenger side plugs. Maybe having uneven worn plugs (good bank and bad bank) causes very rough idling. Maybe the bang/backfire was some of the mass air flow or throttle cleaner I sprayed in... I'm trying to diagnose the issues and need to figure out the wiring diagram to see if it's worth putting more time in, or did I destroy the engine?
I'm worried I've damaged the internals. I'm hoping this is easily fixable and not a destroyed motor...
I guess the first step is the correct diagram... I've looked in my manual, and in Chilton. Nothing. Seems to me this would be essential. Anyone have one to share?
I've now seen at least 3 different charts. I'm very confused. Any owners out there have the confirmed correct chart and diagram?
Here's the one I "think" is correct from research and looking at my motor, but could use feedback or confirmation or correction.
