WickedWindsor
- March 8, 2005
- Ontario, Canada
- 351 powered, 1991 XLT 4x4
Today I flexed out my truck to see what it would look like after removing the overload springs.
I got great flex but noticed the stuffed side spring had a negative arch to it. I don't have bump stops installed, yet.
Is it safe to run off road like this, or am I going to bust a spring eventually? Would it be wise to install bumpstops to prevent the spring from arching too far negative?
I could see axle wrap maybe being an issue while stuffed as well.
If I install bump stops, should I mount them a few inches in front of the axle instead of over the axle? I'm thinking this may help prevent axle wrap under spring compression.
