LMHmedchem
- October 28, 2011
- 2002 Explorer XLT v8
Hello,
I am sitting around waiting for a rebuilt rack and pinion that will be shipped eventually, I hope. I am also waiting for it to not be 14 degrees out like it was yesterday morning.
I have my front calipers off because I am doing some suspension work along with the rack and pinion. I always bring my calipers into the shop and clean them well when I do the brakes. I have toyed with the idea of painting them with POR-15 Rust Preventive, but that's a bit over the top even for me.
I will rebuild the calipers with new slide pins, vibration dampener bushings, boots, bolts, and slippers. Most of this comes with the brake pads. The rest is only $4 per wheel so I think it's well worth it.
I was wondering if anyone has replaced the seals on their calipers,
RAYBESTOS WK2857 Element3 Caliper Repair Kit ($4)
I would go ahead and do this as well if it's not a nightmare. I would rather not get the calipers taken apart and then realize that I can't get them back together, or get the seals sealed, etc. These are the original calipers, so they are going on 20 years old. Everything needs to be replaced eventually but apart from looking rusty like everything under a truck in this part of the country, I have never had any leaks or freezes that I know of.
If anyone has any experience with this I would appreciate some advice. Is this a good idea or should I leave well enough alone until a problem appears?
LMHmedchem
LMHmedchem
