i just had to pull one of my lens out because it had moisture in it. above your turn signals, there is a flap, open it (or your can take the entire black panel off, there are four 10mm bolts there in front of the rad, unscrew them and remove the panel there is two screws there for your turn signal lens, remove them, and pop your turn signal lens out (they will be stubborn, but they will come). next there are two screws near the top center of the grill, remove them. then if you look where your turn signals were, there is one screw (one on passengers, one on drivers side). remove them. then your can remove your grille (it will be clipped in, and it too will be a little stubborn, but it will come). now if you look at your head light lens, you will have two prongs, at the top (one in each corner) and one at the bottom (close the outer part of the lens). take a pair of needle nose pliers, squeeze the prongs together, and lightly pull. your lens will come out, and you can do what you need to. if this dose not help, i will try and get you some pictures later on in the next few days if i have time. hope this helps.
