esclamada
- October 25, 2010
- KCMO
- '02 Mountaineer AWD V8
Yes, great write up! It really helps when you can see pictures. I'm still not "geting" the whole 2x4 / breaker bar leverage thing. It looks like the 2x4 is touching the floor at your feet. So you'd only be able to pivot upwards from that angle. Downward if in the rear. I don't have a breaker bar... looks like I'll need one huh?
Did you use one of those ratchet wrenches that are angled to get those strut bolts out? Those were a pain to get to. Very tedious.
I'm assuming that nothing needs to be "torqued" when put back together right? Just wrenched tightly?
EDIT: Just noticed that you indeed do need a torq wrench. I'll rent one that goes beyond 150lbs.
Good call on the lube the day before. My rears are fine though, but the fronts are probably corroded.
the lower control arm can't be lowered down easily by stepping on it, you need some leverage to step on at a comfortable position (such as standing straight) The breaker bar is optional, I tried using it but it requires a lot of effort since it's too short and moves around (that's why I put the other end in one of the holes in the frame) I prefer to use a torq wrench especially when doing suspension stuff. They are not that expensive in Harbor Freight ($10)
Those angle ratchet helps a lot (they're only $5), it takes forever to remove all 3.
