You got that right! The pictures provided, were worthless! I had to just sit there for a while with the parts in my hands after tearing my engine bay apart and look to see how things really went! Plan for extending the wiring, plan for not recieving the fan wrenches(I didnt), go to Auto Zone and just borrow them, plan on your alternator brackets to be messed up, plan on getting a different length serpentine belt than what comes with the kit, planon having to really work with the front left hose going around the supercharger bracketry and into the water pump. Like Beau said, take the radiator out. I pretty much took the whole front end off because I hate so much to work in tight areas. Once you get good at it you will be able to do it all pretty quickly. Onething you can choose to worry about or not is that your A/C lines go through your radiator too so when you loosen them they will be spewing alot of nice green stuff(refrigerant) which is illegal to do(blahblahblah). If your installing the XB-1A head unit instead of the BD-11 head unit then you will have a really fun time (pain in the arse!!!) tapping the oil pan while not getting shavings into it. I suggest an oil change right after doing this just to be safe. I used thick white grease and stuck mostof the shavings to the tap flutes. You will then have to pull the oil pressure sensing unit and install an extension and a tee off of it to run your oil line to the XB-1A. Make sure you got this right and damn good and sealed! If it leaks it will cost you a total re-tear down(it was not fun). If you dont have an XB head unit, which I sense that 98% of people doing this install will not, then disregard those pointers. Bottom line is that like Beau said, the instructions suck!!! I actually wrote Powerdyne of this and even included my revisions to their instructions and more detailed pictures of what was needed to be seen and never got any reply. I guess they didnt like someone hitting on their terrible instructions. Good luck.
