guitarfrk741
- January 21, 2007
- Baton Rouge
- '02 4.0
First i know i've asked this before..and i am in no way doubting the info that i've been given but ive been doing some research and please just hear me out..
i own a 3rd gen mounty.. 2wd..
now say i had the opportunity to get all the front axle/driveshaft/etc. (which will bolt on, i have checked the mounts) and possibly even the awd tcase..(which should also mount on).
i am nearly positive the awd conversion will work..
now say a 3rd gen 4wd tcase were made availableto me..
now i know these are electric shifting and blah blah computers make it nearly impossible to add on..so i'm thinking AROUND the electronic shifting part to leave out the computer
now this is where i start assuming,as i dont have a 4wd case to look at..but once you get past the shift motor ...shouldn't it look something like this?
if so i'm sure it's more than pheasable that a type of cable or other manual mechanism could be fabbed up to shift the case manually, bc if i understand correctly the turning of that shaft is what engages/disengages 4hi/lo?
also ,if i'm correct there are no sensors in the tcase (3rd gen)that are vital to anything except the controlling of the 4wd in itself, and at that they just send feedback to the control module so it can know when it is or isnt in 4wd
now thats just from what i've been reading and i am in no way an expert in this area...i just wanted to clearly present myself and am looking for opinions
