MickeySpiers
- July 31, 2001
- Littleton, Colorado
- 1991 XLT
Patient is a '97 Limited with a V8. Long story short, replacing the front axle and half shafts (CVs, whatever you want to call them) alleviated the issue of dragging the front wheels across concrete when trying to reverse. Replacing the rear axle alleviated the issue of the truck sounding like it would tear itself apart when a turn was made (never seen a diff lock solid before, but this one did). However, when I finally installed a front driveshaft & turning the truck back into AWD, I was rewarded with a major driveline bind. I can grind the truck to a halt by initiating a tight turn, and half throttle in a well running V8 is required to move the thing at full lock. Straight lines are OK but you can still feel a little pull. Pull the front driveshaft, no problems, it drifts through turns like it should. Front diff is OK, wheels off the ground will spin freely like they are supposed to. I've read all the threads talking about an AWD truck drifting if the front shaft is pulled, trans is in park and no Ebrake, but mine doesn't do that. My driveway is very steep, there is no e-brake as I haven't adjusted them after replacing the rear end yet, and with no front driveshaft the thing doesn't move an inch when in park. I've read that when the t-case in an QWD goes, the viscous coupling burns up, but is it possible this one has frozen? Anything else I should look at?
