Mutineer
- August 23, 2005
- Location
- Ardmore, AL
- Ardmore, AL
- 1997 Explorer XLT 4X4
- Callsign
- FLOYD
OK Ive been reading posts for three days on this. MOUNTAINEERGREEN has put some good stuff on here, as well as several others.
I have a 98 Mountaineer AWD, and I am installing the BW4406 E.S. Tcase. I have done the SAS and have Manual locking hubs.
I have the selector switch from a 1996 4X4, and shift motor from the same.
OK I could care less about automatic 4wd.
I want to rig this up so that I have 2WD, 4 High, and 4 Low.
Seems to me I can bypass the GEM and wire power to the switch, and from there wire it to the motor. My understanding is that it will be resistor controlled from the switch...
The GEM controls engine RPM, Automatic shifting of the 4WD, stuff like that right? Well if I dont want Automatic 4WD, can it not be wired directly to the Motor and have it lock to 4WD all the time when the switch is in Auto? Of course Ill have to stop and be in neutral when I shift it, since the controls and safety features wont be there due to the lack of a GEM, but Im TOTALLY OK with that, especially since I have an SAS with manual hubs.
I will do a full writeup on this when I do it too, as the only way right now to get any good info is going through all the threads that have anything to do with a BW4406 so you can get links to the 50 diferent threads that have a piece of information in them and then move on to other options.
Any help here would be appreciated, if there are opinions and such, but I will be using the BW4406e I have, and not swapping to something else, so lets find a viable solution for this issue that we can pass on.
Thanks Yall
*EDIT* If I missed a thread that does actually address this issue rather than moving to other options, please clue me in. I figured 3 days of reading and not finding anything that really helped was enough.
Thanks Yall
