Axle Pivot Drop Brackets | Ford Explorer Forums
yourmoma717
Norfolk, Virginia
92 SPORT
I just put on a 4'' coil spring lift, and i have realized i need axle pivot drop brackets, where can I get these?
The top of the tires bow out rediculously, other than those brackets, does anyone have another suggestions?
skyjacker, superlift,james duff, 4 wheel parts...i've been looking fo over a month for used ones for 4x4 and they are hard to find because people move up in lift size and give them to their friends...
there is no other way other than those brackets. You just need to find someone selling thing, check rrorc, trs, ebay and on this forum for people selling them.
I'll buy your drop brackets from you.
Well, I found them, they aren't cheap, but they're actually called center hinge brackets
no, according to superlift they are called axle/beam drop brackets.
how much are they?
correct skyjacker calls them center hinge brackets. They should be around $200 from skyjacker. If your on a budget try rough country. Their drop bracket is only 3" but will work for your lift.
