janderson4010
Moderator Emeritus
- August 15, 2009
- third boxcar, midnight train
- 86 BII
I run a d30 for the time being and I needed to truss the axle, so this is what I came up with last night, took about 3 hrs to build and I think it significantly stiffened the d30 axle tube.
3" .25" wall tube split with the plasma cutter,
clamped onto the axle tube,
I welded the seams and ground them smooth, wanted it to look like I had slid it on,
then I burned in the windows I had cut, looks cool IMO and it gives a little more surface area to weld to,
and here is the mostly finished product,
