thefranchise713
- April 22, 2016
- Buffalo, NY
- '18 Toyota Prius Prime
Hi all,
I need your help again.
When braking sometimes, the b-pillar decides to make a pop or groan noise on the initial application. Sometimes you can get 2-3 pops in succession with increased braking.
It does sound like it's trim noise inside of the cabin. I've pulled apart the b-pillar top to bottom but can't find anything loose, and I've also lubricated the weather strips on the adjoining doors, along with lubricated the latches. The top piece of the assembly feels tight, though the bottom piece slightly less so.
Any ideas? The weather strip does seem a little saggy on that side of the car, but it is holding up for the moment.
