2001 Explorer Sport Trac, backup light fuse (27) will hold for a day or two then blow, backup lights, auto door locks and OD quit working when blown. Put up with this for a few years now. Last night I thought I found my problem but after reading this thread I am not sure, I will check the wiring in the column shifter.
I though it worth mentioning last night I started tracing the wiring harness from the passenger side tail light down across to the drivers side, then where it routes to the front of the truck I found the approximately 1/2" harness jammed between a vertical plate and a horizontal plate in the chassis just above the back of the spare. There is about a 1.5 inch hole in the horizontal plate where I can see the vertical plate and the cable is half into the edge of the hole. I can feel it, its wedged really tight, seems like if I could move it to center in the hole it could snake around the vertical plate. I really can't get to it or budge it much, its pretty high up in the frame, class 4 hitch receiver in the way, etc, seems like I would have to do a lot of work to get to this. Just thinking 15 years of vibration on a pinched cable cannot be good. Terrible design to route like this. I wonder if there is a hole in the vertical plate and the factory miss-routed.
In any case I will check the cable in the steering column tonight and post an update. Not sure how to post the pic I will check out the faq's. Looks like I need to upload to a website and cannot directly attach.
