Bad BCM? ForSCAN Results | Ford Explorer Forums
CK6695
Walnutport
2017 Ford Explorer Base
Good evening!
Recently Purchased a 2017 Ford Explorer Base 3.5 NA with 125k miles. Looking to fix it up but getting stumped on the issue before just “throwing” parts at it.
-Airbag Light on
-TPMS malfunction
-4wd malfunction service required
-Black radio screen
-HVAC heat stuck on - turns high once driving and cannot turn off.
I replaced the battery and tried resetting the BCM with no luck.
No visable damage to wires or signs of water entry from what I can tell.
Any help would be greatly appreciated !
Attached below were my ForSCAN results:
===PCM DTC P06E9:00-28===
Code: P06E9 - Engine Starter Performance
Status:
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
Freeze Frame #1:
Freeze Frame #2:
-EVENT_TIME: -184447281 s (Sat Apr 26 15:39:21 2025) - Event time
-TOTAL_DISTANCE: 201874 km - Total Distance
-FUELSYS: Open Loop - Fuel System Status (Open/Closed Loop)
-LOAD: 0.00 % - Calculated Load Value
-ECT: 22 °C - Engine coolant temperature
-SHRTFT1: 0.00 % - Short term fuel trim 1
-LONGFT1: 3.91 % - Long term fuel trim 1
-SHRTFT2: 0.00 % - Short term fuel trim 2
-LONGFT2: 7.81 % - Long term fuel trim 2
-MAP: 98.0 kPa - Manifold absolute pressure sensor
-RPM: 0 1/min - Engine Revolutions Per Minute
-VSS: 0.0 km/h - Vehicle Speed
-SPARKADV: 0.00 ° - Spark Advance
-IAT: 22 °C - Intake Air Temperature
-RUNTM: 0 s - Time Since Engine Start
-EVAP_PCT: 0.00 % - Commanded Evaporative Purge
-FLI: 72.16 % - Fuel Level
-BARO: 98.0 kPa - Barometric pressure
-VPWR: 9.23 V - Control Module Voltage
-TP_REL: 5.88 % - Relative Throttle Position
-TAC_PCT: 9.41 % - Commanded Throttle Actuator Control
-RPMDSD: 1200 1/min - Desired Idle Speed RPM
-O2S12: 1.62 V - Heated Exhaust Gas Oxygen Sensor (bank 1, sensor 2)
-O2S22: 1.64 V - Heated Exhaust Gas Oxygen Sensor (bank 2, sensor 2)
-TQ_CNTRL: None Requested - Torque Control Requested
-APP_FLT: No Fault - Accelerator Pedal Position Sensor Status
-CHT_F: No Fault - Cylinder Head Temperature Sensor Status
-CHTIL: Off - Cylinder Head Temperature Indicator Lamp
-ETC_TRIM_LRN: Yes - Throttle Angle Offset has Learned
-IAT_F: No Fault - Inlet Air Temperature Sensor Status
-MISFIRE: No - Engine Misfire currently detected
-TP_F: No Fault - Throttle Position Sensor Status
-FF_LRND: No - Inferred Flex Fuel Learned
-MP_LRN: Yes - Misfire Profile Correction Learned
-MAF_F: No Fault - Mass Air Flow Sensor Status
-MAP_F: No Fault - Manifold Absolute Pressure Sensor Status
-OTS_STAT: Enabled - One-Touch Start Status
-SMC_MON: Off - Starter Motor Control Output Detected
-STRT_RLY: Disabled - Starter Motor Relay Enable
-APP1: 0.75 V - Accelerator pedal position sensor 1
-APP2: 0.38 V - Accelerator pedal position sensor 2
-TP1: 4.09 V - Throttle Position Sensor 1
-TP2: 1.24 V - Throttle Position Sensor 2
-GEAR: 1 - Gear Commanded
-GEAR_OSC: 1 - Gear Command by Output State Control
-TSS_SRC: 0 1/min - Actual Turbine Shaft Speed
-OSS_SRC: 0 1/min - Actual Output Shaft Speed
-TFT: 21 °C - Transmission Fluid Temperature
-TR: Park - Transmission range
===END PCM DTC P06E9:00-28===
===OBDII DTC None===
Successful DTC reading, no error codes found
Module: On Board Diagnostic II
===END OBDII DTC None===
===APIM DTC U0257:00-0B===
Code: U0257 - Lost Communication With Front Controls / Display Interface Module
Status:
- DTC Present at Time of Request
Module: Accessory Protocol Interface Module
===END APIM DTC U0257:00-0B===
===APIM DTC U3003:16-08===
Code: U3003 - Battery Voltage
Additional Fault Symptom:
- Circuit Voltage Below Threshold
Status:
===END APIM DTC U3003:16-08===
===BdyCM DTC B124D:02-8A===
Code: B124D - Tire Pressure Sensor
- General Signal Failure
Status:
- Malfunction Indicator Lamp is On for this DTC
Module: Body Control Module
===END BdyCM DTC B124D:02-8A===
===BdyCM DTC B1D02:15-48===
Code: B1D02 - Left High Beam Circuit
- Circuit Short To Battery Or Open
Status:
- Test not complete
===END BdyCM DTC B1D02:15-48===
===BdyCM DTC U3006:16-08===
Code: U3006 - Control Module Input Power A Circuit / Open
Status:
===END BdyCM DTC U3006:16-08===
===BdyCM DTC U3007:16-08===
Code: U3007 - Control Module Input Power B Circuit / Open
Status:
===END BdyCM DTC U3007:16-08===
===BdyCM DTC U3013:16-08===
Code: U3013 - Control Module Input Power C Circuit / Open
Status:
===END BdyCM DTC U3013:16-08===
===BdyCM DTC U3014:16-08===
Code: U3014 - Control Module Input Power D Circuit / Open
Status:
===END BdyCM DTC U3014:16-08===
===BdyCM DTC B115E:08-0A===
Code: B115E - Camera Module
- Bus Signal/Message Failures
Status:
===END BdyCM DTC B115E:08-0A===
===BdyCM DTC U0184:87-0A===
Code: U0184 - Lost Communication With Radio
- Missing Message
Status:
===END BdyCM DTC U0184:87-0A===
===BdyCM DTC B1438:03-08===
Code: B1438 - Battery Current Sensor
- Frequency Modulated / Pulse Width Modulated Failures
Status:
===END BdyCM DTC B1438:03-08===
===BECMB DTC None===
Module: Battery Energy Control Module B
===END BECMB DTC None===
===FCIMB DTC U0257:00-0A===
Status:
Module: Front Controls Interface Module B
===END FCIMB DTC U0257:00-0A===
===ATCM DTC U0100:00-0A===
Code: U0100 - Lost Communication With ECM/PCM A
Status:
Module: All Terrain Control Module
===END ATCM DTC U0100:00-0A===
===RHVAC DTC None===
Module: Rear Heating Ventilation Air Conditioning
===END RHVAC DTC None===
===OCS DTC U3003:16-28===
Status:
Module: Occupant Classification System Module
===END OCS DTC U3003:16-28===
===OCS DTC B0061:12-28===
Code: B0061 - Passenger Seatbelt Tension Sensor
Status:
===END OCS DTC B0061:12-28===
===ABS DTC C0051:67-68===
Code: C0051 - Steering Wheel Position Sensor
- Signal Incorrect After Event
Status:
- Test not complete
Module: Antilock braking system
Freeze Frame #1:
-EVENT_TIME: -185458372 s (Mon Apr 14 22:47:50 2025) - Event time
-TOTAL_DISTANCE: 201580 km - Total Distance
-MODULE_VOLTAGE: 13.8 V - Control Module Voltage
-OUTDOOR_TEMPERATURE: 11 °C - Outside temperature
-POWER_MODE: Running - Power Mode Status
-ABS: Inactive - ABS
-AYC: Inactive - AYC
-BTCS: Inactive - BTCS -201D
-HDC: Inactive - HDC
-RSC: Inactive - RSC
-BTC: Inactive - BTC
-VAC_BST_ST: Inactive - Active Vacuum Booster State
-BST_REL_SW: Inactive - Booster Release Switch State
-HYD_PMP_ST: Inactive - Hydraulic Pump State
-ECU_POWER_SUPPLY: 13.7 V - ECU Power Supply Voltage
-VSS: 67.0 km/h - Vehicle Speed
===END ABS DTC C0051:67-68===
===ABS DTC U3003:16-68===
Status:
- Test not complete
Freeze Frame #1:
-POWER_MODE: Undefined - Power Mode Status
-ECU_POWER_SUPPLY: 6.9 V - ECU Power Supply Voltage
===END ABS DTC U3003:16-68===
===RTM DTC None===
Module: Radio Transceiver Module
===END RTM DTC None===
===RCM DTC U0112:00-8B===
Code: U0112 - Lost Communication With Battery Energy Control Module B
Status:
Module: Restraint Control Module
===END RCM DTC U0112:00-8B===
===RCM DTC U3003:16-08===
Status:
===END RCM DTC U3003:16-08===
===RCM DTC U0557:82-8B===
Code: U0557 - Invalid Data Received From Front Controls Interface Module A
- Alive/Sequence Counter Incorrect/Not Updated
Status:
===END RCM DTC U0557:82-8B===
===HVAC DTC U0140:00-0A===
Code: U0140 - Lost Communication With Body Control Module
Status:
Module: Heating Ventilation Air Conditioning
===END HVAC DTC U0140:00-0A===
===HVAC DTC U0401:82-48===
Code: U0401 - Invalid Data Received from ECM/PCM A
Status:
- Test not complete
===END HVAC DTC U0401:82-48===
===HVAC DTC B1083:07-08===
Code: B1083 - Recirculation Damper Motor
- Mechanical Failures
Status:
===END HVAC DTC B1083:07-08===
===HVAC DTC B1B7D:14-08===
Code: B1B7D - Rear Air Distribution Actuator
- Circuit Short To Ground Or Open
Status:
===END HVAC DTC B1B7D:14-08===
===PSCM DTC U3001:68-08===
Code: U3001 - Control Module Improper Shutdown Performance
- Event Information
Status:
Module: Power Steering Control Module
Freeze Frame #1:
-STEER_FEEL: Comfort - Steering Personalization Status
-SWRS: 0 1/min - Steering Wheel Rotation Speed
-SW_ANGLE: -780.00 ° - Steering Wheel Angle
-SSHFT_TQ_S2: -12.8 Nm - Steering Shaft Torque Sensor #2
-SW_ALIGN_OFSET: 3276.70 ° - Steering Wheel Angle Alignment Offset
-MODULE_VOLTAGE: 11.0 V - Control Module Voltage
-ECU_INTERNAL_TEMPERATURE: 49 °C - ECU Internal Temperature
-EPAS_MOTOR_CUR: 186.50 A - EPAS Motor Current
-PWR_MODE_KEY: Key Out - Power Mode Key State
Freeze Frame #2:
-MODULE_VOLTAGE: 10.8 V - Control Module Voltage
-ECU_INTERNAL_TEMPERATURE: 30 °C - ECU Internal Temperature
-EPAS_MOTOR_CUR: 186.20 A - EPAS Motor Current
===END PSCM DTC U3001:68-08===
===PSCM DTC U3003:16-08===
Status:
Freeze Frame #1:
-SW_ANGLE: 0.00 ° - Steering Wheel Angle
-SSHFT_TQ_S2: -0.7 Nm - Steering Shaft Torque Sensor #2
-SW_ALIGN_OFSET: 87.10 ° - Steering Wheel Angle Alignment Offset
-TOTAL_DISTANCE: 201569 km - Total Distance
-MODULE_VOLTAGE: 7.5 V - Control Module Voltage
-ECU_POWER_SUPPLY: 7.7 V - ECU Power Supply Voltage
-ECU_INTERNAL_TEMPERATURE: 0 °C - ECU Internal Temperature
-EPAS_MOTOR_CUR: 0.70 A - EPAS Motor Current
-PWR_MODE_KEY: Key Recently Out - Power Mode Key State
Freeze Frame #2:
===END PSCM DTC U3003:16-08===
===PSCM DTC U3003:68-08===
- Event Information
Status:
Freeze Frame #1:
-SSHFT_TQ_S2: -0.2 Nm - Steering Shaft Torque Sensor #2
-TOTAL_DISTANCE: 200531 km - Total Distance
-MODULE_VOLTAGE: 10.0 V - Control Module Voltage
-ECU_POWER_SUPPLY: 10.1 V - ECU Power Supply Voltage
-EPAS_MOTOR_CUR: 0.10 A - EPAS Motor Current
Freeze Frame #2:
===END PSCM DTC U3003:68-08===
===PSCM DTC U0001:88-08===
Code: U0001 - High Speed CAN Communication Bus
- Bus Off
Status:
Freeze Frame #1:
-SSHFT_TQ_S2: 0.0 Nm - Steering Shaft Torque Sensor #2
-MODULE_VOLTAGE: 12.5 V - Control Module Voltage
-ECU_POWER_SUPPLY: 12.6 V - ECU Power Supply Voltage
-ECU_INTERNAL_TEMPERATURE: 18 °C - ECU Internal Temperature
-PWR_MODE_KEY: Key Approved - Power Mode Key State
Freeze Frame #2:
-SSHFT_TQ_S2: 0.1 Nm - Steering Shaft Torque Sensor #2
-MODULE_VOLTAGE: 12.8 V - Control Module Voltage
-ECU_POWER_SUPPLY: 12.7 V - ECU Power Supply Voltage
-ECU_INTERNAL_TEMPERATURE: 21 °C - ECU Internal Temperature
-EPAS_MOTOR_CUR: -0.50 A - EPAS Motor Current
===END PSCM DTC U0001:88-08===
===PSCM DTC U0100:00-08===
Status:
Freeze Frame #1:
-SSHFT_TQ_S2: -0.3 Nm - Steering Shaft Torque Sensor #2
-MODULE_VOLTAGE: 13.5 V - Control Module Voltage
-ECU_POWER_SUPPLY: 13.6 V - ECU Power Supply Voltage
-ECU_INTERNAL_TEMPERATURE: 28 °C - ECU Internal Temperature
Freeze Frame #2:
===END PSCM DTC U0100:00-08===
===PSCM DTC U0415:00-08===
Code: U0415 - Invalid Data Received from Anti-Lock Brake System (ABS) Control Module A
Status:
Freeze Frame #1:
-ECU_POWER_SUPPLY: 13.5 V - ECU Power Supply Voltage
-EPAS_MOTOR_CUR: 0.50 A - EPAS Motor Current
Freeze Frame #2:
-SW_ANGLE: 504.60 ° - Steering Wheel Angle
-SSHFT_TQ_S2: -0.1 Nm - Steering Shaft Torque Sensor #2
-SW_ALIGN_OFSET: -505.00 ° - Steering Wheel Angle Alignment Offset
-TOTAL_DISTANCE: 201563 km - Total Distance
-MODULE_VOLTAGE: 14.0 V - Control Module Voltage
-ECU_POWER_SUPPLY: 14.0 V - ECU Power Supply Voltage
-ECU_INTERNAL_TEMPERATURE: 35 °C - ECU Internal Temperature
-EPAS_MOTOR_CUR: 0.00 A - EPAS Motor Current
===END PSCM DTC U0415:00-08===
===ACM DTC U3003:16-08===
Status:
Module: Audio Control Module
===END ACM DTC U3003:16-08===
===SCCM DTC None===
Module: Steering Column Control Module
===END SCCM DTC None===
===IPC DTC U0100:00-0A===
Status:
Module: Instrument Panel Control Module
===END IPC DTC U0100:00-0A===
===IPC DTC U0138:82-0A===
Code: U0138 - Lost Communication with All Terrain Control Module
Status:
===END IPC DTC U0138:82-0A===
===IPC DTC U3003:16-08===
Status:
===END IPC DTC U3003:16-08===
===GWM DTC U2100:00-2B===
Code: U2100 - Initial Configuration Not Complete
Status:
Module: Gateway Module A
===END GWM DTC U2100:00-2B===
===GPSM DTC U3003:16-88===
Status:
Module: Global Positioning System Module
===END GPSM DTC U3003:16-88===
Start by checking EVERY fuse, using a test light.
If any symptoms still exist after you replace the blown fuses, start pulling dash panels to look for wiring damage.
Why did you buy it if you didn't know what the root cause was? What's its history?
Thank you! I checked the fuses for the issues having but not all I’ll go through and check every one. I got this verrrryyyy cheap looking to hopefully fix it. I did all the minor stuff myself electrical was just something I was never good at - I assumed it just needed a new infotainment system which didn’t fix any issues swapping them with another used one.
Welcome to the Forum. :wave:
Many airbag warnings were due to a bad connection under the driver's seat.
When you swapped the infotainment systems did that include the APIM?
Are you able to change the vents that the heat blows from? Dash, floor, defrost etc.
