silky
- April 16, 2008
- 1998 sport
I think my mileage sucks, but why?
btw it's a 1998 exploder with 90,x.. miles on it.
I have looked and there are no exhaust leaks. I inspected a couple of the spark plugs and they look good (they have a grey colour to them which from my research points to a good motor). I replaced the air filter recently and change the oil regularly. I am about to head out and pick up a new fuel filter, thermostat and belt.
2 things I have noticed:
1) I have a sticky throttle cable. Sometimes when you step on the gas from idle it doesn't want to go. You have to give it a hard shove before it will rev the engine. When opening the throttle from the engine bay there is a noticeable stickyness at the throttle body.
2) I have that problem with the driveshaft that causes the clunking when comming to a stop. I forget what it's called, binding slip yolk?
would these cause noticeable reductions in fuel mileage?
any ideas would be appreciated!
thanks,
John
p.s. that 12 mpg is about 70% city, 30% highway. As a reference I was once able to get 600km (~360 miles) out of a tank but that was all highway cruising. And I know these vehicle are not fuel savers but in these days of $1.15 a liter or $4.40 gallons, every bit helps!
thanks,
John
