hornz2000
- September 25, 2001
- Athens, GA
- 1998 Sport
OK guys...I recently acquired a pair of Paradyme Digital3810SL speakers with list price of $1599.00 each. (I got both for $320.00 hehehe). Here are the stats:
Low Frequency Drivers:
2x8" Poly-Laminate Cone Design
Mid-Range Frequency Drivers:
5" Poly-Laminate Cone Design
High Frequency Drivers:
1" Silk Fiber Dome
Frequency Response:
28Hz - 20KHz +/-3dB
Sensitivity:
91dB/1 Watt/1 Meter
Nominal Impedance:
4-8 Ohms
Power Handling Capabilities:
RMS: 150 Watts/Channel
Peak: 350 Watts/Channel
MAX SPL: 111dB
Dimensions:
38"x10"x11"
I don't know if those will help at all but here is my problem:
The back of the speaker has 4 RCA jacks, 2 positive and 2 negative..Is there anyway I can use normal speaker wire with these or at least is there some kind of connector which will do RCA out speaker wire in? I would like to use these with a real nice stereo that uses normal speaker wire pinchers. Thanks a lot.
1" Silk Fiber Dome
Frequency Response:
28Hz - 20KHz +/-3dB
Sensitivity:
91dB/1 Watt/1 Meter
Nominal Impedance:
4-8 Ohms
MAX SPL: 111dB
Dimensions:
38"x10"x11"
