Ball joints, U-joints, Oh what fun...... | Ford Explorer Forums
Hotweels
Calgary,AB
'92 EB
So i go to the parts store and inquire about rebuild parts for the front D35 pos and i get told there are 2 different parts for just about everything and only one (ball joint,u-joint.etc) is the right one, Can some one simplify this for me all i know is its a axel code D4 (3.73ls) and its in a 92 eddie bauer. i had a ball joint replaced once before and they told me it was the cheaper one of the two if this helps.:confused:
Are you doing the work yourself?
Most likely the parts store doesen't list the parts as being for a D35, they normally are listed as "for all except 3.54 ratio" (which is what you want) and "only for 3.54 ratio" (which is a D28). I have run into this alot on Explorers and Rangers.
:88vert Yes i am doing the work myself.
:mrboyle Thank you.
This had me stumped cause i know they stuffed a D28 R&P in some Explorer and Rangers D35's but i knew mine was a D35, well the beer is starting to kick in i think i am going to have some fun.
