theSpoon
- January 9, 2009
- Plantsville, Connecticut
- 97 Sport
so all winter i've been getting one engine code in specific, "bank 2 too lean" and "P0420" for my cat efficiency, i still get the efficiency code but since replacing the crank case vent tube, which I had previously removed and replaced with a filter, the "bank 2 too lean" code stopped showing up.
Has anyone else had this happen? could putting that tube back have fixed my lean condition? the hole on the intake tube was plugged so the only un-metered air going in would have to be through the crank case vent. Recently the weather has also gotten warmer which could have contributed the code not coming up anymore. I just want to know if anyone knows about this, I may do the fuel filter and O-ring seals on the intake just to be on the safe side, but if a filter on the crank case could cause a lean condition it would save me some trouble.
