Battery died.. and more problems | Ford Explorer Forums
Quick
IL
2014 Explorer Sport
Well I was about to leave work, and BAM.. no power.
So after getting ripped off for $210 for a new battery, replacement, and alternator check they said my alternator is only pumping out 30amps..
So now I'm getting a new alternator.. and it is a 95amp which is a stock alternator, right?
Well I was driving with my fog lights on and I turned them off, then back on and they wouldn't come on.. nor do my neons (which are connected together)..
Do you think it has to do with the alternator problem, or a blown fuse..
Thanks guys..
[COLOR=dark blue]Sounds more like a fuse problem than an alternator problem for the lights going out. Most likely they would just be really dim (fogs that is. I don't know how your neons are setup.) if it were the alternator.[/COLOR]
It definitely sounds like a fuse issue, does that fuse keep blowing? 210 for a battery and alternator check??? You really got bent. Strauss does the check for free and has batterys on sale for less than 100.00 every week! Is there something I'm missing?
Check fog lamps because same thing happened to mine
Also check your fuses for correct amp and if blown or not
