mistert2
- September 16, 2012
- Savannah, GA
- 2000 Explorer 4L 6cyl 4x4
I am having a problem with my battery not chrging
First I have just installed a new starter, connections all tight. A new alternator, all connections tight and a new battery, all connections tight. But my charge battery light on my dash is on and I can see the guage is showing low battery and with car running does not go up. I have tested the battery and is showing full charge but the alternator tested is between 9-10+-. So not enough to charge battery.
FYI this is the second alternator because happened on the first so I took back to the "zone" and exchanged but same.
are there any fusible links that could have blown. I have checked fuses and have swapped around the relays thinking maybe blown but still same problem.
What can I do?
What can I do?
