- December 28, 2010
- Russell, Ontario (Ottawa area)
- 2025 Aviator Reserve 201A
- Callsign
- VE3... grid FN25hg
What trim level do you have (Base, XLT, etc.)? You haven't added that to your profile. Some trims have different batteries depending on the features of the vehicle.i need to replace my battery pretty soon. what is the group size, amp and CCA? my present battery has 75ah 700CCA, i'm not concern about the CCA much bec of the hot weather here and the coolest temp is only 15C. i'm wondering if i can go up to let say 80-90 ah? is the heavy duty alternator ok for higher amps or stick with recommended amps?
Here is a chart I found on the Internet. Not sure if it helps at all. http://www.spautoparts.com/documents/batteryspecs.pdf
Your Owner's Manual will show the types recommended for the Explorer.
