Baumann ReCal-Pro shift kit and PML pan install REVIEW!!! | Ford Explorer Forums
Oversquare
Wine Country
'00 XLT 5.0 AWD
This week I dove in and installed my shift kit from Baumann Engineering. I ordered up the “ReCal-Pro†kit for the 4R70W, as well as the bypass clutch control valve. The kit is priced at $119, and $29 for the valve.
I also purchased a Deep finned aluminum pan from PML. It holds an extra 2+ quarts, as well as has a drain plug and is tapped and threaded for a temp sensor. The pan was $155, plus $15 extra for the tapping and threading. More on this later.
http://www.explorerforum.com/forums/showthread.php?t=118026
I’ve installed shift kits before, mostly in old muscle cars. I also have extensive automotive experience and am confident in my abilities. I did this project in my garage with basic hand tools. So basically, know what you’re doing before you start.
I started the project on Monday night, with the goal to get the valve body off. The pan came off drama-free and I let the fluid drain out while I drank some beer(s).
HINT: lay LOTS of cardboard on the floor for your comfort, as well as to catch any spillage. Even if you think you have too much cardboard, you don’t. I used 2 full sized refridgerator boxes (stacked on top of each other) to keep my mess under control, as well as to give me some padding while laying on the cold concrete floor.
Before removing the valve body, you have to disconnect the sensors. Reading the instructions, I located the sensors. FIRST PROBLEM: the sensors are connected with one large plastic connector, not individual wires and clips. The instructions make no mention of this. I CAREFULLY pulled the plastic connector away using a small flat screwdriver.
When I finally got the valve body to release, I wasn’t expecting it to be so heavy. It is full of fluid, and everything is nice and slippery at this point. I lost a bolt in the pan I was using to catch the fluid (I later pulled the bolt out), and also knocked loose a small filter, and a spring and round retainer that mount inside the trans.
The Valve body came apart as expected. HINT: To help remove the gaskets I used a dull putty knife to slip between the valve body and the gaskets. This removed them in one piece and did not leave any residue on the metal surface. Be sure to not scrape the metal surfaces.
Time for the shift firmness selection. My goal was for quicker shifts, but not anything so firm as to upset my “better halfâ€. I want something I can be happy with, and have a woman drive without concern. Of the 5 available selections, I choose Stage *2* (Mild).
Of the first 4 designations of where to drill, #C and #D are not present in my valve body plate. I did not add these holes or make any modifications to these. #E I used the #2 drill bit.
#F offered a bit of confusion. There are “large style†and “small styleâ€, determined by how well the #1 bit will fit though the hole. Well, the #1 fit through, but with no room to spare. The instructions state that it would either NOT fit, or fit WITH room to spare. I was in a pickle. I decided to use the #3 drill bit to enlarge the #F hole.
Step #4, I replaced the stock bypass clutch control valve with the aftermarket one, since you have to remove it anyways.
For steps #5 through #7, I used the “A†setting as a guideline.
I did not go through with Step #5 – 1-2 shift firmness and torque correction. I couldn’t find my snap ring pliers, and can do this step later with the valve body in place if necessary.
I did not go into the servo torque correction steps. I’m not making enough extra TQ to worry about it.
Everything went back together well – although I was confused how far to push the Accumulator Retainer into place. I finally just barely pushed it into place to hold the spring, then put the valve body back on. The small triangle filter that fell out when I removed the valve body did not go back inside. I couldn’t get it to stay while I reinstalled the valve body. I don’t think it will be missed.
With the valve body back in place, and the bolts torqued, gaskets cleaned, and a new filter installed it was time for the new pan.
PML deep sand cast aluminum trans pan. I was initially very impressed with the pan. It is very will built, and looks to be a quality piece. It wasn’t until I installed it did I find the fatal flaw…
(Pics of pan are available, just can't post them)
The drain and temp sending unit holes are on the side closest to the exhaust. And they are CLOSE! I don’t have a sending unit in the hole, but I doubt one would fit between the pan and the pipe. And the drain plug will empty right into the exhaust pipe heat shield, creating a long lasting burnt trans fluid smell as you drive.
Since the Exploder is one of the few that use the 4R70W pan bolt patterns, why didn’t they cast the holes in the opposite side – where there is ample access to them?!!? The world may never know…
HINT: Clean the stock magnet in the stock pan, and place it over one of the “posts†in the PML pan. This will give you added magnetic protection, and the magnet won’t float or move around in the pan. HINT#2: Reuse the "reuseable" factory gasket. It has a metal core and works great!
I initially bought 10 quarts of Valvoline Mercon V fluid. I filled the trans with 6, and started it up. The trans would not go into gear – not good. I then added the other 4 quarts, and it did go into gear, but was slipping horribly. 3 more quarts later, the trans was finally full and driving beautifully.
Overall, I’m happy with the shift quality that I choose. The WOT up-shifts are noticeably quicker, but not at all harsh. The downshifts are crisp and smooth – no jerky here. The part-throttle shifts are improved too! I think I’ve made a great trans even better, and the woman will never know…
If I were to do it again, and didn’t have the “woman†factor, I would have probably installed the Stage 3.
I would give the Baumann ReCal-Pro shift kit an 8 out of 10 overall. The parts were all labeled and even included the necessary drill bits. The instructions were very good, but not the best (see #F and electrical connections). The most daunting task is overcoming the fear of making a small mistake – which is amplified into a big mistake when working with a sensitive transmission. The price is fair for one of the most thought-out trans kits available. http://www.baumannengineering.com/
I would give the PML Deep Trans Pan a 6 out of 10 overall. Excellent construction, great customer service and several options (raw, plated, polished, deep, shallow, hole tapped, etc). All hindered by a high price to pay for a fatal flaw in hole locations. A larger trans cooler may be a better idea (and cheaper). http://www.yourcovers.com/
The whole install took about 6 lazy hours in my garage. If I were working back at the shop, I would have billed an easy 3 hours labor to complete this install.
-Brad
I have it installed on my truck on stage 3 and torque compensation 3 as well (i think thats right)
it is the best performance mod i've made per dollar by far
Hmmm... A 3 page review, and only 1 response. I thought more of this forum..
-B
Although I'd love to chime in, I've got no experience with the 4R70W. My experience has shown me that the two ways of handling more power through a tranny is by increasing the pressures that activate the clutch packs and by adding more friction plates to the clutch packs.
Glad it worked well for you and thanks for the heads-up on the pitfalls. I do have one question - Since the pan is aluminum, why didn't you drill and tap a drain hole on the driver's side while it was out and clean?
Very good question about tapping the pan.
The pan is actually cast with specific bosses that allow tapping. And to do it properly, you have to machind the surface flat, then drill, then tap. It takes a bit of material to keep it strong, not something i would want to do simply through the side of the pan. The bosses are on the passanger side of the pan. There aren't any on the Drivers side.
I do have pics, but don't know how to post without a host.
-B
Good write-up. :thumbsup: I am running stage 3/3. I also agree with expo, this is the best mod-per-dollar thing you can do on the V8 Explorers.... other than cutting up the airbox i guess.... which is technically free. :p
Good write up. I think of all the things you can to an aging trannie with it still in car valve body mods and cleaning probably are the most cost/performance effective. Thanks for taking the time to do the write up. When you can get the pics added in I'll nominate it for "Most valuable" status! Thanks for all the work!
Here are his pics....
One more....
As you can see in the pics, the holes are especially thick (bossed) in the casting. It would require a new casting to move the holes to the other side.
In the first pic, you can see the plated hex-head bolts that the pan came with, as well as the magnetic drain plug, and the plug for the sensor hole.
-B
i rebuilt my 4r70w because the direct clutch pack burnt out... I contemplated putting a shift kit in while i was in there but could not afford it at the time.... I'd have to say the hardest part of the whole process was getting it out of the truck without a lift... That and make sure you lay out where every part goes.... i had mine most of the way built and was ready to put the front pump back on before i realized i had forgotten a seal... it had to come all the way back apart... All in all with a ford rebuild kit from ebay and a new clutch drum it ran about 120 dollars in parts. And about 30 hours of my time of which 80 percent of it was getting it in and out... Wish i had a camera with me while i was doing this iwwould have def gone with the baumann kit though... of all the research i did i found that they were the best in the business
Any pics of the shift kit and valve body?
I plan on doing this mod soon.
-Aaron
no pics of the shift kit or valve body, sorry. THe instructions has several pictures (and much better ones than I could take) to help you through the installation.
My review highlighted the few spots that I felt the instructions weren't strong or my cause any confusion. With the instructions and my review, you should be fine!
-B
I see what you are saying about the drain plug, and if you want/need a full-size plug, I completely agree with you. There is another option - use a piggy-back style drain plug (less than $5 at an automotive parts store) where you just drill a 1/2" hole (no tapping), insert/tighten the outer (large) bolt, and the actual plug is the inner bolt. This keeps from needing the strength of longer threads because you aren't trying to tighten a bolt into aluminum threads (which strips out pretty easy if you get a little ambitious with the wrench). I've added these plugs to my tranny's because I hate taking tranny fluid baths ; )
Here's a pic of the piggy-back bolt w/ nylon washers (I also used some sealant on mine):
My 700R4 pan made by PML had bosses on both sides, and when I ordered they asked which side i wanted drilled and tapped. I'm surprised they don't do that with all their covers.
Brain - Thanks for the tip! The PML pan is a little thick to try. I'll see how it goes when I change the fluid in a few thousand miles.
Jefe - The PML pan for the 4R70W only has the bosses on one side, as you can see. It really pisses me off that I can't use the temp sensor hole that I paid extra for. Eh, oh well.
-B
I bet you could find a 90 deg. fitting to fit the temp gauge in. Though I guess you'd probably want a heat shield between the sender and the exhaust, otherwise it'd just be an inaccurate exhaust temp sender. :p
Also, the fitting that Brain posted (or one similar) is the same one my 700R4 steel trans pan came with. The temp sender will fit in place of the drain plug if you wanted to go that route.
Jefe - I thought about the 90* fitting - and it's STILL too close for that. There is about 1" to 1.5" of clearance between the pan and the exhaust.
It's so close, in fact, I'll be doing temperature testing between the pan and the exhaust to see how much heat is being transferred into the pan. I'll keep ya posted.
-B
My Buamann kit came yesterday, and it's going in tomorrow. I'll take photos and keep everyone updated.
Based on their instructions, I was going to do setting two. But after the responses here, what the hell, setting three it is.
Also, do you really need that much ATF? Whenever I've dropped the pan it's been like 5 quarts to refill.
