Thanks for that link! Man I wish I had known about that Mark VIII fan earlier.
I didn't want to install another factory plastic fan, I'm all about upgrading things while they're taken apart- and modernizing a little too. Well that's what I did, installed an electric fan and thermostat. I used the VSC recommended by Aldive (thanks!). The VSC is my variable speed fan controller. The fan I used is a Maradyne, 2192 CFM. It uses 17 amps, not sure if that's great specs or not but the guy at Murrays Speed shop talked me out of buying a Proform fan because they supposedly had most of them returned broken under warranty. He says the Proforms always break and the Maradynes are reliable. I took his word for some reason and bought the Maradyne. For the money I spent I could have gotten a Flex-a-Lite with the thermostat and shroud.
The new fan only comes on if i'm stuck in traffic for more than 3 minutes without moving. It runs for 30 seconds and shuts off. 99% of the time it never needs to come on. This is a major gain in efficiency for the truck, less parasitic drag, less moving parts and more room under the hood. When the fan is running I'm probably using the same amount of energy as the original fan, but since most of the time it's not even turned on, I have more power.
The controller is adjustable, so I can make it turn on at 160 to 220 degrees. Once it's on it's running at 60% speed. If the temp continues to rise instead of fall, then for the next 10 degrees of getting hotter, the fan will eventually speed up to 100% speed. It also has an option for manual on, and also to turn on with the A/C. It came with plenty of wiring, but no instructions. It also looks like it won't handle getting wet. I'm working on a weather proof enclosure for it.
