ErickSaint
- September 23, 2006
- Milwaukee, WI
- '94 XLT
This weekend I will be pulling my rear window to repair most of the lines on my defroster. Since having the truck I only have 2 lines that work. Everything I have read says to do the repairs with the glass at room temp, so I was going to just pull it off and bring it in the house. I know there are many breaks in the lines so I would like be able to test indoors once the repair paint dries.
What is the best way of doing this? When using a test light (self powered or otherwise) my guess is it would still show continuity because there are 2 lines that work, therefore making a connection. Same would most likely apply with my DMM set for continuity.
I do have a 12v power supply from when I used to work on CB and stereo hardware. The problem is it's 13.8v with 10 amp constant and 12 amp surge, so my guess is that the defroster would put my PS in protection mode pretty quick, I know it draws more than 12 amps.
Radio Shack used to sell a "Circuit Writer" pen that I have been told works just like the kit, for half the price, but no local RS stores have them any more. If I could find that I would just mask off every line and apply a whole new line instead if trying to find every little break (there are many from what I can see) looks like the previous owner used to close the glass on things all the time. The kit from checker auto is $12 and comes with a tiny bottle of the paint.
Any tips so I don't have to try installing, removing and reinstalling if all breaks are not found. Wouldn't be so much of a problem in summer, but it's supposed to be a high of 7 degrees on the weekend so doing it outside just seems out of the question.
