Best Summer Weight Oil for High Mileage 1998 Explorer XLT?
sjochssr
1998 XLT 4.0L SOHC
Sorry to be so long-winded... but I have a question about whether or not to use a higher viscosity oil in my 1998 Explorer. The vehicle is a 1998 Explorer XLT 4.0L V6 SOHC VIN E. It has 466,000 miles on it. With my last kid in college, and going into her senior year this Fall... I really need to keep this thing running for one more year. I've only put 5W30 Mobil 1 Full Synthetic from day one. About two years ago, the vehicle started to "diesel" or make a rattling sound from the right front engine (driver's side). I'm familiar with the plastic cassette timing chain deterioration on the 4.0L SOHC, and guess it's likely the problem. I replaced the two front timing chain tensioners a couple of years ago but the ones I took off were in perfect shape. No issues. The rattling noise only really occurs after I drive it, stop for a few minutes, and then drive it again. On start-up after it's warm, the rattling is fairly loud. I've always been curious if the rattling could be something other than timing chains, such as maybe the vehicle needs new upper and lower manifold gaskets. I don't have any error codes though. And I'm getting ready to change the PCV valve. Anyway, does anyone have a recommendation whether I should bump the summer weight viscosity beyond Ford's specs to possible help with the (apparent) timing chain issue? I live in Northern Virginia. Hot (85+), & muggy from April through early October. Appreciate any thoughts or recs.
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
10W-40 wouldn't hurt it, but the issue will need attention most likely before a year is up. The 4.0 external tensioners are fairly easy to replace, way better than the internal parts, and timing cassettes. I suggest doing at least those two parts, they don't cost that much, under $100(OEM) and the labor isn't too bad. It's not easy to find a synthetic 10W-40, but that's what I use in my 4.0 Explorer in Summer.
I have a similar noise from my 1995 4.6 SOHC Crown Vic, and have used a thicker oil since a rattle began years ago. That's a different engine and likely not the same issue, but thicker oil has alleviated the sound most of the time. I've tried to add some STP additives or occasionally etc.
E Best Shocks 2001 Exp XLT AWD??? Stock 1995 - 2001 Explorers 4
G Is there a consensus yet on the new best replacement for Sway Bar Links? Stock 1995 - 2001 Explorers 1
3 Best Adhesive to Reattach Window to 2 small tracks Stock 1995 - 2001 Explorers 4
M PSA - Best oil for M5OD transmission Stock 1995 - 2001 Explorers 2
E Best oil pump for 2001 4.0 SOHC??? Stock 1995 - 2001 Explorers 9
E Best starter for 2nd gen Stock 1995 - 2001 Explorers 12
M Best shocks 1996 RWD explorer Stock 1995 - 2001 Explorers 5
K Best headlights for 1999 Explorer XLT? Stock 1995 - 2001 Explorers 9
L Best v8 engine replacement for 2000 explorer Stock 1995 - 2001 Explorers 2
Cuco BEST OBD2 for $50 Stock 1995 - 2001 Explorers 3
Skip Towne My best thread Stock 1995 - 2001 Explorers 2
allmyEXes Best brand parts for 1997 SOHC engine Stock 1995 - 2001 Explorers 6
Indispensable Explorer Solved What's the Best Way to Roll Forward JY Odometer? Stock 1995 - 2001 Explorers 14
B What's the best sequence for tear apart & rebuild? Stock 1995 - 2001 Explorers 11
9 Best Battery Stock 1995 - 2001 Explorers 72
2 Best way to relieve fuel line pressure? Stock 1995 - 2001 Explorers 11
bigred4x4 Best cv axles Stock 1995 - 2001 Explorers 15
D Best and cheapest radio for 1995 Explorer XLT Stock 1995 - 2001 Explorers 12
3 Best approach to replacing front suspension parts Stock 1995 - 2001 Explorers 23
1 Which exhaust is best? Stock 1995 - 2001 Explorers 1
3 Best after market radiator brand? Stock 1995 - 2001 Explorers 10
9 Best Trans fluid? Stock 1995 - 2001 Explorers 6
F Best way to repair BIG patch of missing paint? Stock 1995 - 2001 Explorers 1
J Best tires? Stock 1995 - 2001 Explorers 17
prayforsurf0 Best cold start procedure for high mileage explorer Stock 1995 - 2001 Explorers 6
L Best Alternator Stock 1995 - 2001 Explorers 5
H What wheel offset will work best? Stock 1995 - 2001 Explorers 1
M Best sealant for water pump gasket? Stock 1995 - 2001 Explorers 5
B Best OBDII App (Bluetooth) Stock 1995 - 2001 Explorers 2
A Third gen Explorer: which year best to buy used? Stock 1995 - 2001 Explorers 17
B Best Muffler for Stock 1997 Exp. Limited 5.0 Stock 1995 - 2001 Explorers 1
O Side View Mirror - What is the best brand? Stock 1995 - 2001 Explorers 12
H Best Friends Stock 1995 - 2001 Explorers 4
D Best way to remove stripped cylinder head bolt? Stock 1995 - 2001 Explorers 16
N Best Stock Condition Explorer of Today: Post Your Pictures w/ Mileage! Stock 1995 - 2001 Explorers 11
C Back again...Best serpentine belt? Stock 1995 - 2001 Explorers 7
P Best Use For Rear Wiper/Washer Stock 1995 - 2001 Explorers 5
S What are the best body bushings? Stock 1995 - 2001 Explorers 1
X what's the best choice for lower control arms? Stock 1995 - 2001 Explorers 31
M Best shocks for 1999 Mercury Mountaineer 5.0 Stock 1995 - 2001 Explorers 12
A Best spark plugs Stock 1995 - 2001 Explorers 21
G best way to change the downstream O2 sensors on a 97 sport Stock 1995 - 2001 Explorers 10
F Alternator is dying, best replacement? Stock 1995 - 2001 Explorers 12
P What's the best option for a tired suspension? Stock 1995 - 2001 Explorers 10
swshawaii Best Door Lock & Latch lubricant? Stock 1995 - 2001 Explorers 21
P Best way to go about repairing the 5.0 exhaust manifold? Stock 1995 - 2001 Explorers 15
P Best way to remove surface rust on frame and undercoat? Stock 1995 - 2001 Explorers 3
Rick List of Useful Threads Stock 2nd Gen Forum's Best Threads Stock 1995 - 2001 Explorers 1
ninety9sport Best Floormats for a Manual Sport? Stock 1995 - 2001 Explorers 6
U Best "Stock" Catback Exhaust? Stock 1995 - 2001 Explorers 9
Similar threads
