demon2091tb
- October 11, 2003
- Clinton, NC
- 99' XLS
I want to upgrade my big 3 wires under the hood, does anyone have any pictures and step by step instructions for upgrading the big 3, i was hoping to put 1/0 guage wire in them because i will be running a HiFonics BX1500D and probobly the ZX4000 on my stock 90 amp alt. very soon, any help is appreciated!
Big 3.........
The Big 3 Are:
1. negative battery wire to ground - just replace the negative batt. terminal and wire and ground it to the factory location
2. engine block to ground - replace the ground wire from the engine block to the chasie with a bigger wire (maybe 4 guage)
3. alternator to batt - add a fused wire from the postive post on you alternator (the one comming from the battery) to the postive terminal on your battery. DO NOT exchange wires just add a extra one. make sure it fused the same size as your factory fuse.
hope thats helps
I do not actually know wher any of these places are, thats why i was hoping someone had a diagram with step by step instructions. thanks.
Big 3.........
The Big 3 Are:
hope thats helps
