Wish I still had my Ex. Now that I just scored a $75K fleet mechanic position. Timing can suck some times.
I was very careful, especially with the brake lines. I cut them flat with a 4.5" thin cut-off wheel, then rounded both tabs off at the same time with a flat 40 grit flap disk.Nice work...those Radflos look sweet. I bet those lower mounts were fun to trim with limited space to maneuver the grinder.
Thank youVery nice truck sir.
No rear shock upgrades at the moment.Just to put another spike in your wallet!
Are you thinking it's time to upgrade the rear shocks? RadFlos maybe?
I have it on the work bench, its on my list of stuff to think about for awhile, then jump in.Are you gonna do the Freak'n-stein steering shaft while your in there? I'm interested to see what you come up with.
I am planning on taking it for a drive tomorrow, but not sure if any dirt will be involved. Noticed my secret testing area that was 15 minutes from my house has a new locked gate. The shop I purchased them through said I will be very happy with the difference. He mentioned that Radflo's have "progressive" dampening that adjusts for the terrain and type of driving. We will see about that, my friends!Glad to see the coil overs in. Can't wait for thewhen you get it in the dirt.
I have a single sheer pitman arm. Would have to get it tig'd to turn it into double sheer, then it might have clearance issues with the track bar.
I thought about sleeving it, but am looking into options of having a local machine shop make me a tapered OD, straight 3/4" ID SS sleeve. Then I wouldn't have to make the pitman hole any bigger, and the tapered sleeve would lock itself into the tapered hole in the pitman. All they would have to do is turn-down some thick walled 3/4" ID SS tube at the right width and angle. Need to see if its cost effective.
Took the Explorer around town this morning. It rides very nice on the street, with less body roll that before. Drove over a couple of curbs just for fun, and it was very smooth. Need to go out and really wheel it, but I am going to tear into the oil leaks first.
