Blower questions / resistor identification and replacement | Ford Explorer Forums
kaczman
ohio
2002 Heavily Modified ST
Hello all,
My blower motor only works on the highest setting. 1 is non existent, and 2-3 just slowly blow if at all. Is the resistor part of the heater a/c control unit? I cant seem to find a correct replacement for my 02 Sport trac.
Outside, under the hood, right side, behind the cruise control.
Original Ford F5TZ19A706B
AIRTEX / WELLS Part # 4P1368
Alternate/OEM Part Number(s): 4L5Z19A706AA, F57Z19A706B, F5TZ19A706A, F5TZ19A706B,
Sounds like the resistor, not the switch, correct?
Thanks bud. I ordered the resistor now. Thanks for the picture. I wish I could give you some well deserved reputation for this and helping me out on the rubber pieces on the bed.
Well I replaced the resistor and.... the plug was burned. Any idea where I can get another, or the applications this fits? If I check blower motor, I see any 00-05 Explorer or 00-11 Ranger will work. Any other ideas? All I need is the factory plug to repin or wire.
Can't help with that one. I know on my sisters Volvo the same thing happened and it required replacing the motor.
edit- Now that I just looked what the resister looks like I understand what you are saying. Maybe time to hit up a junkyard or ebay.
