rocco123
- February 24, 2002
- Endicott, NY
- 1994 XLT & 2002 Limited
After hearing a chirp from the right front area of my 02 limited, I discovered it is coming from the body mount that is below the forward hinge point of the front passenger door (right fwd mount). There is metal to metal contact where the mount (rubber bushing) goes thru the bracket mount hole coming off of the frame. I was wondering if there are aftermarket RUBBER body mounts out there. I don't like the idea of installing a poly-mount as I believe that area should have some sort of cushion to it. What are the options (other than expensive dealer parts).
