nrancour
- May 9, 2011
- Houston, Texas
- 2002 Mountaineer Premier
I have a 2002 Moutaineer (4.0L-V6).
As of late, it has been rattling quite a bit when I hit a pot hole.
When I hit a pot hole I feel a loud thump right under the driver's side floor board.
I replaced all the sway bar bushings & links and noticed that all my body mounts have deteriorated to NOTHING.
I found a parts list on ford.com with a callout list.
Here is the list......(sorry for the spacing)
The dealer wants $1800 for a complete set.
I verified that with an indy, who wants another $1800 to install them.
I haven't found any aftermarket kits for 2002 Explorer/Mountaineer.
Daystar says the much referenced kit KF04009BK will not fit the Gen3.
With all the Gen3s out there, there has to be an aftermarket solution.
Is there another solution?
Help!
Code:
Callout Cost Quanity Total Description
<00145 $29.81 2 $59.62 Body shim 2mm
<00154A $109.56 2 $219.12 Body mount insulator
<00154B $106.59 4 $426.36 Body mount insulator
<00154C $29.54 2 $59.08 Body mount insulator
<00154D $29.64 2 $59.28 Body mount insulator
<00155A $23.61 2 $47.22 Body mount insulator
<00155B $139.50 4 $558.00 Body mount insulator
<00155C $24.93 2 $49.86 Body mount insulator
<00155D $39.72 2 $79.44 Body mount insulator
HB1 (6) $69.64 2 $139.28 Bolt M12 x 72mm (4/pack)
HB2 (2) $16.83 1 $16.83 Bolt M12 x 1.75 x 100 (4/pack)
HB3 (2) $8.60 1 $8.60 Bolt M12 x 105mm (2/pack)
HN1 (2) $13.45 1 $13.45 Nut M12 x 1.75 (4/pack)
HW1 (10) $13.45 3 $40.35 Washer 13mm x 57 x 4.8 Rect (4/pack)
$1,776.49
Help!
