Does anyone know if there is a bolt pattern difference between my 96 X and a 85 full size Bronco. And if so what is the bolt pattern for the Bronco. I got a deal in the working and I need to know if these rims will work. Thanks.
The only full size Broncs with solid fronts were 78-79.Originally posted by Ford_Racing_Guy
do the 85's have the Straight axle in front?
if not you should look for an older bronco like a late 70's that has the straight-axle
