liv2surf34
- September 15, 2003
- Jacksonville, Fl
- '98 Eddie Bauer
Ok so im gonna start building my box, do i need the 3/4 inch mdf or will 1/2 be fine?
liv2surf34 said:well sh*t, i just went to home depot and bought 1/2 hahahah, is it gonna affect the sound or anything?
I agree.410Fortune said:5/8" is the stuff to use....
410Fortune said:actually you have to also consider deflection, with 1/2" MDF or HDF, and a sealed enclosure depending on the size the wood will actually bend under the pressure from the woofer, expanding and decreasing the volume of the box, not good.
410Fortune said:hahaha 3/4 is overkill
But it will work good! You can use 1/2" too, but its best to use bracing on all the edges with 1/2".......
