FYI No 2 jaw puller is needed to pull the bars. I went to the junk yard with Ben to get the new bar and it only took a couple mins. We didnt have a puller but I have taken torsion bars out of a few things without ever using one. its easy, here we go
Jack under controll arm, not tight but support the arm.
Disconnect shock
Disconnect sway bar
crank adjuster all the way out
Remove skid plate at adjuster
Lower jack
remove cross piece for adjuster
remove the adjuster itself (may need a pry bar to twist it a little to get it to let go)
slide out bar.
Thats it guys. Took well under 15 mins to take the bar out of the truck at the yard.
