jake the snake
- March 23, 2003
- Louisiana
- 2002 XLT 4x4 4.0/SOHC
ugh!!
i decided i was going to try to see how easily i could loosen the nuts on the front shocks, to see if i could tackle changing them out myself with hand tools. on the front driver's side, i put a ratchet on the bottom shock mount, barely torqued on it, and sheared the stud off that is attached to the radius arm.
**i drilled a hole next to the stud, and have a bolt holding the shock on for now. (its the original motorcraft shock...11 yrs/125k mi. old)--how long will it hold?
can i replace the stud? should i? how do i do it? what else could i do?
