Racerx70
Another Broco2erer
- August 10, 2004
- Soldotna Alaska
- 89 Bronco2
I am in process of a full-width axle swap, springover rear. 4.88's and spool/locker and have been thinking about more gearing. I want to use a EB dana20 case that I have. Mainly for strength and it's compactness.
I thought about trying to couple it directly to my A4LD, but 25spline to 28 doesn't work. I would need a new output shaft.
So, I was thinking about trying to mate it to the front section of an extra Electric 1350? case I have. The adapter itself is no problem, but the shaft could be. Does anyone know if there is enough meat on the stock output shaft right behind the Planetaries to go 28spline?
I just wanted to see if anyone knew, before I go tear apart a pefectly good t-case.
