Ronin8002
- March 23, 2003
- Virginia
- 2008 XLT Ironman
So it seems I have a slight bump or bubble on the outside sidewall of one of my tires (Mickey Thompson Baja ATZ Radial 265/75/16, load range E).
It's about 2" wide and extends from near the bead all the way up to the shoulder of the tread. It sticks out maybe 1/4" at the furthest...hardly even noticeable...only reason I saw it is I was about to wash the truck and noticed that some of the lines/letters on the tire were distorted in one spot. You can feel where it is when you run your finger around the sidewall.
I have no idea how long its been there. I don't recall hitting any bad potholes or sharp objects that would cause that kind of damage. I thought it was a defect but Mickey Thompson won't replace it under warranty because they consider it to be damage caused by the owner
Fortunately I have a spare one that's already mounted on the same type rim....I'm just a little irritated that a 3-ply sidewall tire could get "damaged" that easily.
Is it unsafe to drive on the tire with the bubble on it? I figure it will get worse with time but until then I thought I could put some more miles on it before it gets big enough to be unsafe. Or am I asking for trouble doing even that?
Here are some pics...it's really hard to see it so I circled it:
