superfestiva
- October 27, 2006
- Santo Domingo
- Explorer 2003 XLT 4WD
Hi:
I used the search feature and found nothing useful...this code in bare english what does it mean? the shop says I have to buy a new ABS module, why?
I also have c1236 and c1235 codes which generally are when the rear sensor by the differential goes bad, I can buy that since it's not that expensive, but the abs module is expensive and don't want to spend the money if the abs light won't come off...
The hubs are ok, no vertical or horizontal play, cruise control is ok, 4x4 is ok, no humming sounds while cruising, all sensors where cleaned, right front sensor changed...uhhhhhh!!! Help!!!
