Cabin air problem | Ford Explorer Forums
Cabin air problem
dwkexplorer
Central Missouri
2001 Explorer
Hello, everyone.
I have a 2001 explorer. There is a problem with air flow from the ac vents to the defrost vents. What I notice is traveling up hill, the ac vents reduces in air flow to zero but the defrost vents increase in air flow. I have also noticed that if I let off the gas going up hill, the air flow returns to the ac vents. When travel down hill, ac vents flows ok. I think it is vaccum related but not sure. Any information is helpfull from anyone. Thank you, dwkexplorer
Welcome to this forum! It sounds like a vacuum related problem. This is usually caused by partially cracked plastic vacuum tubing near the vacuum control servo. Check the vacuum reserve canister for cracks as well.
welcome
Thank you
Thank you
