429CJ-3X2
- November 6, 2009
- Des Moines, Iowa
- '01,'02, '04 Sport Tracs,
I knew I shouldn't have said it's fixed! After driving it for several days with the brake pedal travel being better and acceptable, as we left for my granddaughter's dance recital last night, the brake light came on. Should have, but didn't, switch vehicles.
This morning, I found a leak at the rearmost line on the master cylinder. It was tight, but leaking, so I tightened it some more and set about bleeding the brakes. That was an ordeal in itself. I knew one of the rear bleeders was rounded off and had already bought new ones. Should have read the reviews. The Brake Best bleeders from O'Reilly's are not a direct fit. One reviewer said they don't work on a '02 Sport Trac. They leak no matter how much you tighten them. Took those back and exchanged them for the Dorman bleeders I had used on my '01. Couldn't get those to stop leaking either. The tip is slightly longer, wider, and more pointed than the originals and don't seat properly. I ended up taking the Dorman bleeders out of the front calipers, and FINALLY got one to seal, but I had to really crank it down. I'll be looking for original bleeders at the salvage yard in the future.
After thoroughly bleeding all 4 corners, I went for a test drive and found the pedal feel is right back where I started. Got home and checked the rear bleeders for leaks. They look ok. Went to the left front and saw fresh brake fluid on the ground and dripping from the inner fender. When I got a helper, I quickly found the rear fitting is still leaking profusely when the brakes are applied. For some reason, that line and master cylinder don't seal. That was not what initially caused the long pedal travel though. The pedal felt pretty good after switching master cylinders until I ran it low last night. It didn't feel that bad even until I lost all that fluid trying to get a bleeder to seal in the rear. I'll try the line from the '01 that was originally mated to this master cylinder.
