- January 17, 2000
- Pinole, CA
- 2001 F250/XLT Superduty
- Callsign
- KG6MAX
Ok, so I took the ol' 93 navajo out for a drive the other day. For those who remember, when I drove to Moab, it over heated, and started to have stumbling/hestation problems when I got to moab. I haven't fixed it yet, simply because I'm reluctant to do 'sensor of the day' repairs, and wanted to see if I waited long enough, the culprit part would die.
I did however, get to swap a known good mass air sensor in one time, and the problem still existed.
Ok, back to the road trip. The truck's check engine light came on, and off.. and so on, until I got home. The truck will also stumble, and hesitate also at this point when given partial throttle, under load (ie, between 1k and 2.5k rpms, in 5th gear). The truck runs perfectly fine until this occurs. This doesn't occur until the truck has completly warmed up (it takes about 20 minutes of driving). Temp is just into the normal range (which is 'normal' for this truck).
So I pulled over, and hooked up the test jumper, and started to read codes.
I got from the computer:
172 - lean condition, right side
176 - lean condition, left side
185 - mass air flow lower than expected
186 - injector pulse width lower than expected
172
176
185
186
I also hooked up a fuel pressure gauge, and got 40lbs of pressure engine off, 30 running, 40 w/vacum line pulled from the regulator. (which is in spec)
Ok, so I'm thinking it's a bad Throttle Position Sensor. (Mac also is guessing that - he played with it a Hollister before he left, and thought it was acting slow to respond to the gas pedal) Here's the deal - before I take it in, let's see who can guess what's wrong!
Ok boys, I'm ready for ideas.
172
176
185
186
