camber caster shims | Ford Explorer Forums
camber caster shims
tigercat
Perry, Fl
'92 sport
where can i get oversized camber caster shims for a 1992 explorer 2wd and how much$ are they?
I've only seen Camber adjusters which go around the ball joints or Excentric Radius arm bushings (used for caster correction).
The caster adjusters are made by moog and aren't normal RA bushings. The hole is off center and you can rotate it to lift it up or down some. If you go off road don't both with them. I've shattered two sets. I now just live with the caster being off and use Moog Problem Solver rubber RA bushings.
~Mark
A caster/camber kit from someplace like Jegs or 4wheel parts should not run you more than $35-$40 per side
if i left it stock would there really be a need for them i do drive mostly on the road but i could do often tire rotation?
