"Maxed out"
Thanks...
This is going back to January when I had uppers and lowers balljoints replaced.....at the time, they told me that the shims that were in the truck were already maxed out....and that no further camber could be gained....
Well, the front drievr tire wore very bald on the inside, so I know SOMETHING is up....
So I take it to a different shop yesterday and they tell me that I need to have shims installed on both sides...I recall ".5 degree" being mentioned on the parts list.....I got scared off due to teh labor fee ($55 per side) and stopped them...
After checking here I find that that is reasonble, so I made some more calls.....other places wanted more.
SO I called the place where I originally had the work done and the guy there said $170 for alignment AND shims both sides....but that on 94 Explorers you can only shim so far and then that is it....you can do a toe-only alignment at that point.....He said I could swing by and he would look at it and tell me if it was "maxed out or not" but that he couldnt do the alignment till next week (booked solid)....
Far as I know, nothing is bent or anything.....I was thinking what you said...it doesnt amke sense that "for whatever reason" it cant be aligned.....new balljoints and nothing visibly bent, how can this be??
And what is involved in putting these shims in?? One place told me that it is a one-bolt thing, another said that the whole front end has to come apart....one shop said 45 minutes, another said 80 minutes, another said 2-3 hours.....ARGGGGGGGGGG!
WHY CANT I GET A STRAIGHT ANSWER from shops on this that jive with the others?!?!? <grin> I feel like Charlie Brown after Lucy yanks the ball away...again.
Thanks to anyone who can help...
DZ
