tooltime
- April 18, 2012
- Las Vegas, Nv
- 2002 Explorer Sport Trac
I have an 02 ST 2wd pre-runner in the works. It came with headers. My question is; There is some sort of warm air emission (assuming) bronze in color pipe coming from the left side header and going directly and connecting into a valve or something in the intake area by the throttle body. Its feeding hot air right into the motor. That has to hurt performance! second question; Can I remove it by capping off both ends, and what will be the side effects if any? Will it throw a code? Will it pass smog? Will the truck run better since its not getting hot engine exhaust fed rigth into it? I live in the Southwest, so winter mornings arent much to speak of, at least compared to those cold Chicago winters I grew up with. Lastly, Its rubbing on my newly replaced steering shaft. If I cant remove it due to codes or wont pass smog ect.,, I can bend it slightly out of the way. Any thoughts????? Im all ears, or eyes in this case. Thanks in advance.
