schmidlkofer
- March 1, 2007
- thornton, colorado.
- 94 XLT
give up either have a explorer or a mustang.
If you want to do it right, start with Torque Monster Headers, then build a quality exhaust behind them.
The rear 02 sensors monitor the front cats function--nothing more.
You need those, as well as the front cats, no, do not gut them.
Like mountaineergreen said--get the Torquemonster headers--and go from there.
Remember this though--a balanced sound is hard to achieve on explorers--
the mustang has the benefit of having equal length tubes-running down the center of the car.
Ours go all the way over to one side--making the driver side exhaust at least 3 feet longer than the passenger side At the point it starts to turn rearward, it is already "de tuned", for lack of better terms
I believe this to be the obstacle, however, if it was thought out well, it could be balanced for a good "tuned sound"
Maybe add a resonator to one side for more air volume?
The O2 sensors should be changed regularly, not just when they go bad. For what gas costs now O2 sensor should be fresh, and synthetic fluids should be in everything. Night,
To make it sound like a Mustang you need a H-pipe first of all
replace the rear O2s with "MIL Eliminators" or figure out what resistance you need and splice them in (thats all they are).
DO NOT eliminate the front O2s.
Ok I've just got to chime in here. Both my front two cats are gone (straight pipe instead), the rear two are empty, and the muffler was replaced with a pair of "twister turbo" mufflers. It used to be dueled off out the back, but I broke a couple of hangers on the trail. I just cut it off about 3 inches past the rear doors (5 inches of pipe past the mufflers). I don't have any CEL, and it's been this way for about 4 years (3 months cut off). Just my 2 cents.
In the interest of all-
The advice which is being discussed disturbs me.
I'm afraid others will be drawn in to this foolery. We are not talking about "off road use only" trucks here. just my .02
So you mean that you have no pre-cats at all and it runs fine? No check engine light at all? What did you do about your O2 sensor that is located on your pre-cat? If you say that your engine is running fine without any cats at all then im hacking my other two off this weekend.
Thanks,
Colton
