skelley
- April 21, 2012
- 2002 Ford Explorer (V6)
My issue started when I began getting P0174 codes for System Too Lean, Bank 2.
I found the most common mentioned issue on forums was that there was likely a vacuum leak, or a bad intake manifold gasket. I didn't find any noticeably damaged vacuum hoses so I figured I'd replaced the intake manifold gaskets since that would be a cheap (although not incredibly easy) fix.
Once I got the SOHC Intake removed I noticed something ODD... One of the six intakes on the block looked different. 5 of them were black with a fair amount of buildup, but 1 of them was almost clean, just with an oily film. I've attached a photo.
My question is, would a bad gasket on that intake cause this...or do I have a more serious problem deeper in the engine?
