jremington59
- October 28, 2009
- Watertown, NY
- 1997, 99 and 2000 5.0's
I have a 97 5.0 AWD Explorer, but it has a motor that is a 96. I found out today that ford put some 96 motors in some of the early 97 Explorers. Anyways. Before I found this out the dealer gave me a printout of the motor components as I threw a P0401 code. This printout showed an EGR tube and a seperate DPFE sensor. When in truth, my 97 has the EGR valve with the sensor that bolts to the end of the EGR valve.
My question is, does that sensor that bolts onto the EGR valve serve the purpose that the seperate DPFE sensor does? Also I read there are internal ports that supply the returned exhaust to the engine. Can someone tell me where these internal ports are located as in my readings I read that these ports can become plugged the same as an EGR tube can become plugged.
I'd like to start getting this fixed, but I'd like to make sure I have some understanding of how the EGR setup works in this engine.
I did change the control valve that is to the left of the EGR valve and it still kicked the check engine light after it was replaced.
