spobely
- September 25, 2023
- Alberta
- 1998 SOHC XLT
Hey,
So I pulled out my LH timing tensioner with great difficulty because I thought I could get the thing done without pulling the intake. At this point I decided this was out of my league and I'm paying a shop to put the new tensioners in. When I was putting the fan back in, the accessories moved slightly, with the belt wrapped tight around everything. Thus I'm guessing the crank moved ever so slightly.
This is a dumb question, but is it possible its "jumped" off the teeth of the gears? Having seen many videos and many cutaways, it looks like it should be fine as the tensioner doesn't even supply tension when off. I understand that they are there for the slack side of the revolution, and I swore I've seen people bar the engine over to get it to the "easy" side for tensioner insertion. It has not been cranked since I've had the tensioner out obviously.
