fast_dave
- June 6, 2005
- East Bay - Nor Cal / PRK
- '98 Spt 4.0 OHV 5 spd 4x4
I have a 1998 Explorer Sport 4WD w/ an X Engine (OHV) and a Standard 5 Speed Transmission.
I highly suspect that the U-Joint that connects the Steering Shaft to the Rack and Pinion Input shaft.
A replacement Lower Steering Shaft w/ U-Joint from FORD is around $276.
A DISCOUNTED replacement Lower Steering Shaft w/ U-Joint off the internet from Fast Parts Network .Com is around $185.
QUESTIONS:
* Has anybody ever removed the Lower Steering Shaft on a 1998 (Or Newer) 4wd Explorer and JUST REPLACED the U-Joint that goes bad???
* I Imagine that FORD welded one end of the u-joint to the Lower Steering Shaft, and at the other end of the U-Joint would be the "pinch bolt" - IS THIS THE CASE OR???????
* Does anybody have a good pic of a 1998 or newer Lower Steering Shaft that has been removed, and that you can clearly see the universal joint that goes bad that would really help as I find a good picture is often worth MORE THAN a 1,000 words....
TIA,
fast_dave
QUESTIONS:
TIA,
fast_dave
