MO_GUY
- October 17, 2002
- Farber, MO
- 2000 Explo Sport 4.0 SOHC
When I charged my friends capacitor the voltage wouldn't stay up? Should the capacitor be hooked into the amp's power also or what? I had a ground wire and the power wire that comes from the battery.....I hooked the power wire to the + of the cap and put the resistor on the - of the cap and touched the ground to the other end of the resistor, it went up to 12.5 volts then as soon as i stopped touching the resistor with the ground wire the voltage dropped.......why is not holding the charge?
